Storing sails over winter — rolled or folded?
With haul-out season upon us I have been thinking about sail storage. My Hallberg-Rassy has a furling genoa and a slab-reefed main, both about four years old now and in decent shape.
Every year I go back and forth on this. My sailmaker in Pollença says roll them loosely on a tube and store them somewhere dry. A mate in the yard swears by washing them first and folding them flat. The Elvström loft in Palma told me years ago that rolling is better because it avoids crease lines that can weaken the cloth over time.
What does everyone do? And does anyone bother with professional cleaning or is a rinse with fresh water enough? I have never had them professionally cleaned in four seasons and they look fine but I am starting to wonder if the UV damage around the leech is worth getting looked at before I put them away.
James, I have been rolling my sails for the last fifteen years and I am never going back to folding. The crease argument is real — I had a genoa develop a hard crease line along the foot from being folded the same way three winters in a row, and the sailmaker in Porto Pi said it weakened the cloth enough that he could see it starting to go.
What I do with my Bavaria is take both sails off in early November, give them a proper freshwater wash on the hard standing (I just lay them out on the concrete and use a hose, nothing fancy), let them dry completely in the sun for a day, then roll them loosely onto the longest cardboard tubes I can find. The chandlery at STP usually has some if you ask.
I store them in the aft cabin standing upright. Some people take them home but honestly if the boat is dry inside they are fine aboard. The important thing is they are not sitting in a damp locker.
Professional cleaning I have done once in ten years when the genoa got some mildew after a wet autumn. Otherwise the hose and a soft brush does the job.
Rolling for me too. My Day Skipper instructor drilled it into us — never fold along the same line twice if you can help it.
I do not have my own boat yet so this is mostly theoretical but I helped a friend at Club de Mar take his sails down last November and the washing step made a huge difference. They had some salt crust along the leech that came off easily with fresh water but would probably have turned into something worse over winter.
Carlos, do you do anything special for the UV strip on the genoa? My friend was told to treat his with some kind of fabric protector but it sounded a bit excessive.
Sophie, the UV strip is worth keeping an eye on but I would not bother with fabric protector sprays. I tried one years ago — cannot remember the brand — and it left a sticky residue that attracted more dirt than it repelled.
What I do is just inspect the strip each autumn when I take the genoa off. If the stitching is still tight and the cloth is not going brittle, leave it alone. The UV strip is designed to take the punishment so the sail cloth underneath does not have to. When it does start to go you will see the thread pulling through — that is when you get it re-stitched, not before.
My sailmaker at Porto Pi charges around 8 euros per metre for replacing a UV strip which is not bad considering a new genoa would be several thousand.
On the charter boats I manage we roll everything and store them in sail bags with silica gel packets — works well enough in the Mallorcan humidity. The one thing I will add is check your battens before you store. I had a full-length top batten crack over winter last year because it went in with a tiny stress mark I did not notice. Replacing it in April when you want to be sailing is annoying.
Also if anyone is using a sail laundry rather than doing it themselves, the guys at Veleria Balear near the Club de Mar do a decent job for a reasonable price.
This is really helpful to read even though I do not own a boat. Last week at the school they started taking the sails off one of the training boats and I got to help — it was my first time actually handling a sail on the ground and I was surprised how heavy a genoa is when it is not flying!
Katrin, the silica gel packets tip is great. Does anyone reuse them or do you just buy new ones each year? My German practicality is kicking in here.
Anna, you can absolutely reuse them. I buy the big bags of silica gel from a ferretería and just spread them out in the sun for a few hours to dry them out again before the next season. They change colour when they are saturated — white to pink or blue to clear depending on the type — so you know when they need refreshing.
I put them inside the sail bags but also scatter a few around the lazarette where I store lines and fenders. The humidity here does not really drop much even in winter so it is worth the effort.
