I’ve been dealing with osmosis blisters on my hull and I know it’s a common issue, especially for boats that have spent time in warm Mediterranean waters. Here’s what I’ve learned through the (expensive) process.
How I discovered it: I noticed small blisters in the gelcoat during a routine haul-out. Pressing them released a vinegary-smelling liquid — classic osmosis.
What the yard said: The blisters were superficial on my boat (gelcoat only, not into the laminate). This is the best-case scenario. If it’s in the laminate, you’re looking at a much bigger job.
The treatment:
- Peel or grind off all gelcoat below the waterline
- Dry the hull completely (this took 3 months in the Med sun — would take longer in northern Europe)
- Apply epoxy barrier coating (multiple layers)
- Re-antifoul
Cost: About €8,000 all-in for a 45-footer. Not cheap but not catastrophic either.
Prevention tips:
- Keep the boat out of the water when you can
- Use good epoxy primers under your antifoul
- Address any blisters early before they spread
Anyone else been through this?
This is quite scary for potential boat buyers! Is osmosis something that would show up on a marine survey? And is it a deal-breaker or just a cost to factor in?
I had the same issue on my Bavaria about 8 years ago. Caught it early and the treatment was similar to yours but cheaper because the boat is smaller. €8k for a 45-footer is actually quite reasonable — I’ve heard of it costing €15k+ on larger boats where the osmosis has gone deep.
The key is catching it early. Check your hull every time you haul out.
One of the advantages of the Hallberg-Rassy is the hull construction — they use vinylester resin below the waterline which is much more resistant to osmosis. Something worth considering when buying a boat. Not all fibreglass is created equal.
That said, I still check mine religiously at every haul-out. Belt and braces.
@tom_lisa A good surveyor will find it — they use a moisture meter to check the hull. It’s not necessarily a deal-breaker but it should definitely be factored into the price. If a boat needs osmosis treatment, negotiate the price down by at least the cost of the repair. Some buyers walk away but you could end up getting a good boat at a discount.
